Old 10-03-2017, 05:39 PM   #28 (permalink)
cajunfj40
Lurking Eco-wall-o-texter
Leak down tests are not easy on an Explorer.
Hello oil pan 4,
Head gasket patch is what you use to get the vehicle sold.
They don't work.
It's more of a temporarily repair till you can get it fixed right. This head gasket rear stuff doesn't stop the leak, it just slows it down.
I'm thinking of it more for a cracked head vs. a blown head gasket. These Cologne OHV v-6's are apparently prone to cracking the heads (though less so on these last few years), causing coolant leaking into the combustion chamber. Symptoms are the same as a blown head gasket in that cylinder, except without the oil/coolant mix. With the other coolant leaks, there's more going on than just a crack, so I need to pull the head for sure. Any idea how much of a mess the sodium-silicate "water glass" based head gasket fix products make for the guy replacing the gaskets after it has been used? Not the drop-in stop leak goop, the stuff you have to do with water only, then flush out and replace with coolant after 2 heat cycles.
Not fixing a bad head gasket as soon as possible will lead to cylinder wash down with coolant, which will taper it, then after you fix it you will be burning oil.
Yes, I need to fix it. Trying to figure out how much it needs so I can do the right repair at the least cost. Cost-effective, so to speak. Unfortunately there's no way to check for a cracked head until it is off, and I don't want to spend ~$500 on new heads if the short-block is bad, nor do I want to put shiny new heads on a leaky old short-block. Doing all that work and still having leaks would really make me mad.
So, still working on this thing. Drives nice when it isn't missing. Never overheats. Starts easy.
I tried to do a leak-down test this past weekend. Half a day spent swearing and getting bruised and scratched in the garage and no reliable results. I need to get at a minimum new o-rings for my cylinder adapter, as I strongly suspect I am not getting a decent seal there. The late-model 4.0 OHV Cologne V6 heads take a long-reach 14mm, with the threads in the bottom half of the well, so the regular adapter doesn't fit and my slightly longer one probably engages 2-3 turns at most.
I'll probably try picking up a spark-plug non-fouler to use as an intermediary. It will provide a taper-seat seal to the cylinder head, and an easily cleaned surface for the o-ring on the leak-down adapter to seal against. Then I can mark the harmonic balancer so I can get the engine on TDC properly for each cylinder's compression stroke. I know I got it close - I hooked up the adapter, put a longer hose on it, climbed under the truck, put a ratchet on the nose of the crank and turned it over until I felt/heard compression out the end of the hose. Then kept turning until I couldn't get more air to come out. Problem is, I believe it rotated backward until a valve opened whenever I tried to test it, because I got hissing out the intake at 15psi input on cylinders 1-3, all I had time to do. Gads is it painful to pull and replace plugs/plug wires on this engine! A/C reciever/dryer and lines plus heater lines and valve and blower housing on the passenger side, A/C lines and EGR lines/valve plus brake booster on the driver side.
Pretty sure I did confirm a connection between at least cylinder 3 and the water jacket. I built pressure in the system and pushed out at least a cup of fluid. No bubbles - just a bit of pressure release when pulling the cap and an "upwelling" of fluid.
After I ran out of time, I put the plug from Cylinder 4 into Cylinder 3 and put a new one in 4 while buttoning things up. I was just going to swap between 3 and 4 and see if the misfire moved with the plug from #3, but I preferred no miss (at least for a while) to a moved miss. Plugs look pretty evenly clean except #3, which is tannish/reddish. No fuzz, just colored. ~2,500-2,800 or so on the plugs. No oil-soaked plugs.
The possibility of a cracked head is worrying, mostly from the perspective of "if I plan to just swap the gaskets/head bolts and I find cracked head(s) I'm without a truck until I get un-cracked head(s) and find time to work on it again". Plus I can't replace the pan gasket with the engine in the truck unless I at least drop the front diff. I also don't want to put a bunch of new gaskets/new or rebuilt heads on a worn-out shortblock. Been pricing used engines locally. U-Pull is ~$260 with warranty, $160 without. Other pre-pulled yards are ~$300-$800 "ran good" or "tested" or "150 all" with 150-250k miles on them. Thinking about trying to get a shot at a decent shortblock I can tidy up in prep to swap in, and 2 more heads that might not be cracked. Any warrantied engine I get a chance to test at home and take back if it is "bad" beyond their warranty conditons.
Hard part is getting the heads crack-checked. Maybe I can get lucky and be able to pressure-test a used engine and it doesn't have blown head gaskets. I don't want to replace the head gaskets twice just to check for cracks, and if I take the heads in to get crack-checked, they need to be cleaned, and they ought to have the valves done, etc. and pretty soon why didn't I buy new heads?
This is an intentionally low-dollar vehicle. I'm paying myself in tools to the tune of what the labor estimates are to get various things done, it's the only way I can justify putting any money into it at all. It won't get a $1650+ remanufactured long block, that's for sure. A used "ok" engine, a good gasket set, pick-the-best of what I have for valvegear, manifolds and heads from the two engines, though? Maybe. Might even fool around with seeing if I can clearance an intake manifold to drop straight down over the cam sensor. Pain in the butt to have to drop it down to 1/4" off touching, then scooch it back 1/2", then drop it the rest of the way onto the thick beads of goop that seal the valley. Or use the cheaper 1-piece gasket that's got steel carriers.
Hard to justify much when there are less-rusty and more importantly less-totaled trucks out there for <$2,000. Sunk costs are going to eat me alive on this thing if I don't take a step back and make a plan. At least after the initial spend most of the cost has been tools I get to keep.
