Old 10-05-2017, 02:29 PM   #12 (permalink)
spacemanspif
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
The single cam engine should be good for close to 40mpg without trying. Head over to Saturnfans.com for info on basic maintenance and keeping the powertrain in top shape if you haven't already. On my 1995 SL2 I found an OEM air dam in a JY and installed it since the car didn't come with one and then completely blocked off the whole front end. GM used air dam cooling on Corvette and Camaros for years and it works well as long as the dam is in place. Air dam plus front wheel spats would serve double purpose and supposedly the turbulence through the engine compartment is less severe with dam cooling vs. "ram air" grill cooling. Just food for thought...
If you do a lot of highway driving check the transmission ratio charts and see what ratio 5th you have vs. the other years. 5th is easy to swap on those trans and if you can get a big change might be worth trying to find a gear set off the forums.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
