Old 10-09-2017, 11:34 PM   #44 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Vekke View Post
On the inspection 3 springs were broken and brake hose needs to be changed. Ordered also eibach 30mm lowering spring kit to solve that problem.
Since you're willing to get it lower (for the sake of aerodynamics?), I assume off-road capability is not a top-tier priority for this project. Are you also considering to turn it from AWD to RWD-only in order to decrease transmission drag losses?
