Old 10-15-2017, 09:10 PM   #5 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
People confuse 'speed' with 'energy'.
Unless the hill is so steep that you have to drop back gears or go into fuel enrichment, gaining momentum has the same cost on the flat, up hill and down hill. What goes up, must come down, essentially.
Ideally, you want to crest the hill at such a speed that you end up at the speed limit (or your target speed) at the bottom.
Only accelerate on descents if the next hill you face requires that extra momentum. Otherwise, climb slow and steady, in top gear at BSFC (80% load).
*All assuming you have a NA, throttled spark ignition engine.
I've run a test on hills and indeed you get better economy with hills than without. I have a great hill that I use regularly. It's a steep climb, followed by a shallow decent. BSFC up, EOC down. Crazy mileage.
The Following 6 Users Say Thank You to oldtamiyaphile For This Useful Post:
bikenfool (11-19-2017), Elizabeeth (11-25-2017), JohnAh (11-20-2017), PaleMelanesian (12-04-2017), Panther140 (10-17-2017), Xist (11-22-2017)
