Xist, if you still have access to the old toilet, you could take the tank and see what happens when you fill half the waters area with cement or something lighter to drop the amount of water in tank by half while still getting good hieght and use a 4 inch pipe to keep the cement away from the flushing components. Then you put some little pieces of angle iron at the top of the pipe to give the water a twist to try and get it to shoot through the toilet faster!!
Then you take the composting toilet seats with the separate part for pee that then runs down a 1/2 inch pipe through the toilet so it doesn’t use any water for that anymore?!?
