Old 10-27-2017, 10:07 AM   #5 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
At ~3kWh per mile, that would mean the battery can take a charge rate of 600kWh in 6 minutes, or ... 6 megawatts? A 375v battery would be charging at 16,000 amps. Is my math wrong?
What would that even look like?
I think EVs are around 1 KWh for 3 miles. 225 - 350 W-H per mile is a common range from my reading. Even Jack Rickard's Electric Escalade used 'only' 777 W-H per mile.
So 320 km (from the article) is 200 miles. 200 miles / 3 miles per KW-h is 67 kw-h. 67 KW-h in 6 minutes is 670 kw-h in an hour, or a rate of 670 KW. At 375V that's 1786 amps. I think liquid cooling of the charging connector, charging cable, and battery pack are all required so that nothing melts!
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
