Old 10-27-2017, 11:17 AM   #8 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Said chart is for a 32 kwh battery, and shows it can do 320 km(200 miles) on what it can get in 6 minutes.
Assuming it can safely charge 80% of the battery in that time, like the other rapid-charging of lithium batteries (might even be 90%, looking at the chart's 12 minute and 30 minute charge times), 80% of 32 kw is 25.6kw.
I doubt we're at the point where you can get 7.8 miles per kwh. Or even 6.25, if it got a full 32kw.
But, assuming it could suck in 25.6kw in 6 minutes, that's 256 kw...at 375v, that's still 682 amps...and more with losses.
Hmm. That's a lotta juice. Not impossible, but pretty out there. They'd seriously need to boost the charging voltage to make it reasonable and efficient. Some day, they'll have to have EVs running at thousands of volts rather than just hundreds.
