Old 10-31-2017, 10:06 AM   #26 (permalink)
Piotrsko
Originally Posted by Stubby79 View Post
Now that you mention it, we wouldn't be pumping in crazy amps to the car through a fat wire. We'd be pumping in crazy volts to the can and having the onboard charger convert it from mass volts to mass amps. It would have the shortest conductors reasonably possible after the charger, and there would be no loose connection or anything to worry about. And, since it's contained, it could run liquid cooling of some kind to said conductors, if necessary.
Not sure I'm comfortable with the idea of running 14kV to my car just yet though.
Sounds incredibly inefficient, huge amounts of waste heat just to charge fast.
How to do it..... buck conversion or huge winding transformers? Yucch
