Old 11-04-2017, 06:28 PM   #477 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
FINALLY!!!! The last task in the way of putting the body back on the chassis is DONE!!! On the Prius v, Toyota routes the parking brake cable back behind the Denso A/C unit on the far side from the driver. This made the cable too short to reach the new parking brake pedal position on the Firebird firewall. One last bolt behind the A/C unit was keeping the cable in place. It took an hour and a half with my head upside down lying on the floor of the car, and using three different wrenches to get the bolt loose in the tiny little hole I had access through... but I finally got it. The photo is of the cable pulled out from behind the A/C unit and rerouted to the driver's side. Got-cha you little bugger.
Bill the Engineer
The Following 2 Users Say Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020), Xist (11-05-2017)
