Old 11-09-2017, 03:50 AM   #4 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
As you point out the failur savings are pitiful a penny per thousand miles whereas the extra horsepower required by the oil pump due to higher viscosity can be worth dollars per hundred. Every start is a cold start unless your oil is at operating temp it will take more powerto move the oil , than in a few minutes when completely warmed up. The colder the start the bigger the penalty on a parabolic curve.
Oilpan this point is why you ,I and many others go through such grate lengths to warm the oil in addition to the standerd water heater.
Old tele man
They even admit they are not large oil co. (There still an oil co.).
"As more and more large oil companies switched their "synthetic" motor oils to the less expensive/more profitable Group III (3) base stocks it has become much easier to identify which are PAO based true synthetic. Of the large oil companies, only Mobil 1 Extended Performance, as of this writing (12-16-2012), is still a PAO based true synthetic. The rest, including regular Mobil 1 and Castrol Edge have switched to the cheaper/more profitable Group III (3) petroleum based "synthetic" motor oil. AMSOIL Synthetic Motor Oils are PAO based true synthetic motor oils with the exception of the short oil drain OE and XL synthetic motor oils sold at some Auto Parts Stores and Quick Oil Change Centers.( This sounds like unless you buy direct from supplier even Amsoil is cutting corners as well) This leaves more than 20 PAO based true synthetic motor oils manufactured and marketed by AMSOIL with only a few Group III (3) based synthetic motor oils identified by the "OE" and "XL" product name."
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
