Old 11-16-2017, 01:52 PM   #3130 (permalink)
ScottyWarpNine
EV
Thanks Paul,
That seems to have solved the connect problem. Still won't program though. I get this error message:
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x63ff
configuration memory
program memory
Address: 0 Expected Value: 40100 Received Value: 0
Failed to program device
2017-11-16 12:50:27 -0500 - Programming failed
Pass Count: 0
I'm pretty confident in my solder joints, especially as I soldered a new PIC on and get the same result.
