Could you mount the antenna on your end to a pole on the balcony, or do you have neighbors upstairs? With that hill so close to you, any gains you can make on your end would be worth several times the increase at your parent's.
What's on the tops of those hills? Trees and buildings blocking the view won't help. I doubt the 25km range of that antenna includes such obstacles.
