Old 11-22-2017, 08:40 PM   #1 (permalink)
hat_man
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
OBD2 misfire codes Ford Ranger 2.3l Lima
This question is related to my other thread. I just wanted to separate it as this one is more of a learning question for me, but may be related to my other problem.
http://ecomodder.com/forum/showthrea...age-35859.html
I have a Ford Ranger with a 2.3l Lima. 4 cyl, 8 spark plugs, 2 coil packs. Just had the plugs, wires and coil packs replaced. Truck is down on mpg by about 6mpg and feels sluggish. I'm not getting any misfire codes. I thought the misfire codes were P0300 (Random misfire) and P030x with x being the cylinder. I only have 4 cylinders so I am assuming P0301 thru P0304. With having two coil packs (I think Ford did this to help with emissions) lets say I had a bad coil pack but it's the one that fires at the bottom of the stroke (secondary?). Would it show a code of P0305 thru P0308 for the other coil pack/spark? Or would it just not register at all because the two coil pack set up on a four cylinder isn't a common set up? I know that P0305 thru P0308 are for engines with more than 4 cylinders, but I wondered if Ford used those numbers to cover the extra coil pack/spark plugs. Or if it doesn't register an OBD2 code for the "secondary" coil pack, how would you know if you had a bad one?
Also, if you had a clogged injector but were getting spark from both coil packs, I assume it wouldn't throw a misfire code as it's getting spark, but you would still have a "dead" cylinder as there isn't any fuel to ignite?
Grasping at straws at this point, but still trying to learn.
Thanks
If nice guys finish last, are you willing to pay the price to finish first ?
