Old 11-23-2017, 01:13 PM   #47 (permalink)
The Toecutter
The Toecutter's Avatar
Rebellion - '16 KMX Framekit Custom electric velomobile
I never did get the opportunity to scan my drawing and the camera on my phone broke, but I did manage to test a tailbox some weeks back. The right steering spindle failed at about 25 mph. It required noticeably less effort to push at speed, but my speedometer was broken and I was guessing the speed at which it broke based on cadence and selected gear, but I was no where near topped out. I was only a few blocks from home when it happened, fortunately, and was able to very slowly ride back.
Last weekend I got the trike back on the road. I had to have my suspension blocks modified to fit the dimensions of the new redesigned spindle, and it sat for 2 weeks because of that as well as waiting for the replacement spindles to arrive. I replaced the left one as well; it had cracks across the welds. I was running the gas shocks at 80 psi and have reduced them to 60 psi.
I haven't done anything with my body pieces since that test, but I spent a portion of time after work yesterday carrying about 50 feet of 1-inch pvc pipe cut into 5 foot sections on my lap along with pvc elbows(90 degree and 45 degree) and T-s back home. I'm building a roll cage structure out of it before I mount the front pieces to the tailbox that compose the rearmost 70% of the vehicle dimensions, as well as allowing the body shell to have more permanent and safe mounting points. I'm taking advantage of the 4-day weekend for this and hope to have something more substantial than a tailbox usable before I return to work on Monday. I dont expect to have the hood piece ready, but everything else is a possibility.
Once I have that working, I can build the pieces needed to seal my chainline from the elements and then go about replacing my crankarms, front and rear gearsets, upgrade to trigger shifters, and install a torque-sensing bottom bracket/instrumentation. I want the drivetrain sealed so that the parts get tens of thousands of miles with minimal maintenance, like some commercial velos.
A butterfly-style steering wheel and rack/pinion system may be in its future as well, which the next body will have to be designed around. I might be able to make a NACA0018 layout fit a top cross section of the vehicle perfectly and shape the whole thing with compound curves, which may allow an area around 0.4 m^2 from the reduced width a steering wheel will allow and who knows how low drag coefficient can go on an open wheel design(low 0.2s are possible with open/exposed wheels, but can better be done?), but I will need some software to analyze it and shape it accordingly to my needs BEFORE I go through all the effort to make a plug and lay glass down or try carbon fiber.
