Old 11-30-2017, 09:49 PM   #35 (permalink)
redpoint5
90 day: 29.78 mpg (US)
It also depends on which brand / model you use. The newer Samsung models are rated much better than older SSD's.
And I've got news for you: spinning hard drives break down all the time.
I've dealt with hundreds of failed mechanical hard drives in the course of my IT career, and perhaps half a dozen personal drive failures. Fortunately my drive failures have always occurred as part of a RAID array, so I have never lost data.
It would still be foolish to store important data on a RAID array alone, as a fire, theft or ransomware could render it unrecoverable.
This is a 'next step' deal, but I am considering getting a new power supply for the computer. There doesn't seem to be a great selection of power supplies for a low power system like this. PC parts picker estimates my max power consumption at ~130W. I kind of doubt it'll even get that high. I'm obviously looking for something as efficient as possible as well. Any suggestions?
I'd get something to measure power consumption and go from there. PSU efficiency has a lot to do with buying one rated near the actual loads it will be supplying. Buying a 1000W PSU with 85% efficiency rating will not get 85% efficiency if the load is 50 watts.
These days, for casual home use, I just recommend people use a laptop since it's low power by design, small footprint, quiet, and has built in battery backup. Decent new ones can be had for $300. Better used ones can be had for $200. I give away serviceable used ones frequently (I've got 2 sitting next to me needing a little work before I find a home for them).
