Old 12-03-2017, 09:33 PM   #35 (permalink)
westygo
I had drilled holes at the corners of the tabs to relieve the stress before bending them over. I had been hitting a lot of curbs with the dam, and finally one of the end tabs broke off. Then another etc. The tabs broke right on the bend. So now I am looking for an extruded softer plastic "angle iron" to cut into new brackets instead of the one piece design I had. I will eventually be adding the front belly pan which will take the majority of abuse in the future.
The Following 2 Users Say Thank You to westygo For This Useful Post:
aerohead (12-16-2017), freebeard (12-03-2017)
