Old 12-06-2017, 01:38 AM   #3 (permalink)
Xist
This is the three-ton version: http://ecomodder.com/forum/attachmen...1&d=1512541759
I am not sure that would fit under my Accord and I definitely wonder if I could use that with my Civic, but if you lift cars the Shouty Kilmer way, with just one jack stand in the middle, well, actually, sometimes that would be even less possible.
My issue is that I am supposed to lift the back of my Accord at the tow hook. I bought the biggest truck jack that Napa had and I cannot lift the back of my Accord high enough to fit jack stands under the pinch welds. I ended up putting a 4x4 under the crossmember and lifting carefully, but that did not seem like the right way of doing that.
