It's kinda late. Somewhat pick up what you're saying. Is this kinda how lean burn works? Less fuel and less power so you have to give it more throttle which in turn increases your throttle efficiency? Is that along the lines of the same concept? Cause I get the throttle efficiency because more vacuum the more your piston has to work to draw in air.
