A $50 to $70 digital charger that makes 10 to 15 amp with "standard" or "flooded" setting, an "AGM" and a "gel" setting will be all you need.
You don't have to spend much money to get a special lithium charger.
Charging the lithium will be much more efficient than a lead acid. The lead acid probably requires around 4hr of float time. As soon as the lithium battery hits 14.4 to 14.6 it's all charged up.
