Old 12-10-2017, 11:59 AM   #6 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
The Smart Battery 12V 35AH Lithium Ion Battery features an automatic built in battery protection system (BPS) that keeps the battery running at peak performance and protects the cells for thousands of cycles.
Max Charge / Discharge Current 35A (amps)
You're good to go. It's designed as a drop-in replacement for a lead-acid.
Might want to check what kind of charging amperage your alternator is putting in to it, mind you. The BMS may or may not regulate it down to 35 amps.
The Following User Says Thank You to Stubby79 For This Useful Post:
California98Civic (12-11-2017)
