Old 12-11-2017, 12:03 AM   #8 (permalink)
ExDelayed
ExDelayed's Avatar
Zed - Sold - '14 Honda CR-Z base
Last 3: 44.31 mpg (US)
Christie - '92 Dodge Dakota 4x4 LE
90 day: 17.03 mpg (US)
Smile
Originally Posted by Stubby79 View Post
...and eventually would get around to a compression test if I couldn't find any evidence otherwise.
So kinda backwards, but I had some time to burn and the truck was warm. Spark plugs have normal coloration, and are uniform across all eight. Hot compression test had good results, with less than a 5% variation across all cylinders. I'll be able to let her cool down tomorrow to further investigate/possibly change the coolant sensor.
I did find that the hose from the fuel tank to the charcoal canister was disconnected. I reconnected it, zip tied it so it couldn't escape again, and sprayed all the vacuum lines. No other leaks or disconnected hoses were found.
Last edited by ExDelayed; 12-11-2017 at 12:08 AM.. Reason: Added stuff and spelling
