Identifying the 49 state vs the Ca VX Ecu
[QUOTE=Joseph Davis;25837]Last count I had twelve P07 ECUs on hand. While they can be modified there has been no actual development on them, so they are effectively paperweights. I drop the OBD1 ECU plugs off of them and use them to make pass-through harnesses for various reasons.
Hi,
Is there a way to identify the CA ECU by numbers? I have a '95 VX and I'm sure is a California car with 4 wire O2 and the car's book is in a California dealer folder. But if I look for the 49 state Ecu, how can I be sure I have the right one, as mine says P07?
Thanks,
Scott
