Old 12-11-2017, 10:20 PM   #8 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
The non adjustable one should be coming on at around 120°F so it's probably messed up.
Do you think it comes on during the summer due to high 90*F-100*F heat and the pilot light making heat?
Still, wouldn't it work better if the temperature differential were the same? That is, if it's coming on at 120*F when it's heating 70*F air then shouldn't it come on at 90*F it it's heating 40*F air?
Still, I'll go ahead and test it and see if it's working correctly first before modifying the furnace.
