Originally Posted by jamesqf
If you use some sort of bed liner on top of the carbon fiber, isn't that just increasing the weight that you're trying to reduce with carbon fiber?
In the end, even after a carbon fiber bed is fitted with a liner, it's still supposed to remain lighter than a steel bed without the liner.
Another advantage is that it won't be so prone to damage like sheetmetal beds that corrode due to moisture buildups between the bed and the liner.
