Old 12-13-2017, 03:00 PM   #50 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
One option with the A/T tires I did was look for some new truck takeoffs. These guys dropping 60k on a new truck often want big tires and custom wheels so there are nice mounted and balanced highway tires all over Craigslist with little use. I got a set, wheels and tires, off a 2015 with 8000 miles on them for $350. They are also taller, 33", than my stock tires, 31.5", which helped drop my cruise rpm a bit. In my case the extra height on the truck doesn't matter as the camper behind it is way more frontal aera than the truck will be.
I still want to do a cedar strip aero bed cover with the possibility of being able to angle it up as a deflector when towing. One I want to learn the technique, two I want to have a dry place to store stuff not towing, three they look freaking sweet if you saw the tread with the Toyota one.
The Following User Says Thank You to Hersbird For This Useful Post:
slowmover (12-14-2017)
