Old 12-15-2017, 02:34 AM   #12 (permalink)
ExDelayed
ExDelayed's Avatar
Zed - Sold - '14 Honda CR-Z base
Last 3: 44.31 mpg (US)
Christie - '92 Dodge Dakota 4x4 LE
90 day: 17.03 mpg (US)
Getting to the bottom of the list one thing at a time. I knew the injector seals were old and hard, so it got new ones installed today. The truck's coolant sensor showed proper resistance and the ECU's reference ground is good. The only thing left would be the gauge, that is almost a full sweep under cold, even when off. I'll hit up the wrecking yard tomorrow and find one. If that doesn't change anything, all that is left is the cold. The only thing I can't figure out, is why I had the drop before it started to get cold.
It's thermos is almost complete. It's going to go from full rich, to having plenty of warm coolant on hand to help it on the cold days.
Originally Posted by twj347 View Post
Are your winter tires new or did you use them last winter also? They could have significantly higher rolling resistance than your summer tires. That, combined with cooler temperatures could explain the drop in fuel efficiency. It's a good idea to do a coastdown test when switching to new tires so you can quantify the difference.
European 30W oils are a little thicker than 30W oils in North America, but you wouldn't notice more than a 1% difference in fuel economy because of this.
The tires were used, but they weren't on the truck at all last winter. I knew of the oil being slightly thicker, but along those lines, I drained out 5w30 Mobil 1, for the 0w30 Castrol, which adds another (small and irrelevant) variable.
Thermostat stuck open?
Already looked there, and the truck does get to operating temperature fairly quickly.
