Old 12-18-2017, 12:20 AM   #7 (permalink)
freebeard
Volt-Ohm-Milliampere. AKA multimeter aka what you have in hand. You can measure voltage drops across a component or switch to Ohms and chase bad grounds.
My problem is finding one of the two or three that doesn't need more than a battery.
You should be able to get by with a continuity tester. That and a length of wire to extend it's reach.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Xist (12-18-2017)
