Old 12-18-2017, 10:19 AM   #1 (permalink)
Daox
Circulating tank block heater maintenance
I went about flushing the radiator core on my Mirage this weekend, and at the same time I was going to install my Kats 1000W block heater that I had on my Chevy Metro. The heater is absolutely wonderful and warmed up the engine coolant in about a half hour on the Metro.
I grabbed the heater and pulled off the hoses. This is what I found. There were signs that it had been leaking a little, and the clamp was not nearly as tight as it should have been. You really do need to check these clamps and re-tighten them after a week or two because I know I put that sucker on tight. I assume its the heat cycling that does it.
In any case, I took it apart and cleaned it up. This is what is inside for those who wondered. I know I did.
And its all cleaned up and ready to go into the Mirage now.
ID:	23183   Click image for larger version
ID:	23184   Click image for larger version
The Following 2 Users Say Thank You to Daox For This Useful Post:
Ecky (12-18-2017), Xist (12-18-2017)
