Old 08-24-2008, 01:37 PM   #26 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by RH77 View Post
First welcome...
Next -- I tried this 3 years ago by running my 4-cyl as two, by switched injector deactivation. Forget it if you're running an oxygen sensor, it will not work. An engine swap would be easier...
RH77
It should be a bit easier w/ 6s/8s when they shut off a bank since they tend to have a oxygen sensor for each bank and maybe something post cat. Unhooking the post cat and deactivated bank sensors would probably result in thrown codes but it should still run at ~stoich via the feedback from the activated sensor/bank. I think knock sensors may also hurt efficiency by retarding timing but I'm not sure about that one. The best way to figure this out would be a test I suppose.
