Old 12-21-2017, 03:41 AM   #2 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
32/36 is what is called for on my '87 Ram D-50 2.6 for the Webber conversation , 105hp. Without supporting modds ; intske , cam , header,and exhaust the larger carbs are just toomuch carb. So I've read.
Throw a vacuum gage on it .1-3" at wide open mid to red line and the carb is the point of restriction, and bigger is warnted. 0"of vac means just right or too big. Over size is only good at top end and compromises mid and bottom rpm.
My boss from years ago had a pair 42mm's on his 69VW bug . Poor thing would pull the front tires off the ground, catching second gear. He had to delete the viscosity stacks to get the carbs to fit under the hood with only a 3"offset. When he did he had to rejet to compinsate for less/ more turbulent air entering the carb.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
