Old 12-22-2017, 08:00 PM   #5 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I think you have this backwards. Water holds 1 cal/gram°C. Oil hold from .4 to .5 cal/gram°C depending on the oil. That means if we have both fluids of equal volume that are heated at the same rate, the oil would heat up roughly twice as fast.
Indeed I was possibly confusing with boiling point.
Personally, I would try to find a 12V pad heater if solar is the only way you're going to power it. It just makes the system way more simple, and less components to break in the future. I know we like to think all electronics should last forever, but they don't sadly.
The conundrum is that the inverter could be used to run the odd mains powered tool or charger. I feel that the probably higher quality mains heater is likely the more robust solution, but also the more expensive.
I think I'll try the cheap 12v heater first - the 80*C thermostat is a major draw card. I can't imagine that temperature ever harming the oil.
The stick on ones kind of suck.
You can not connect a stand alone inverter directly to solar panels. The panel ocv is too high for the inverter, then under load it will likely undervolt fault.
I have several posts on heating oil. None involve stick on heaters.
I have solar controllers of course. The inverter would be running off that, or failing that off the battery via a relay connected to the controller load.
Bare in mind factory warranty - stick on is about my only option for the moment. I accept it's not the most effective option, an immersion heater will have to wait.
