Old 12-25-2017, 04:55 AM   #7 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by puddleglum View Post
Yes my small converter is similar to that one, but a little different. I might pick one of those up though. Looks interesting and has a wider voltage range than mine.
I was concerned the reverse power output from the Alt. might damage the converter without a diode. You don't think it would?
That was just the first once that I came across that could handle most ebike voltages. If you're not running a BMS (because your pack isn't lead), just watch out that it doesn't drop your battery voltage past it's lower limit; these things don't have a set low-voltage shut-off.
I doubt that it will be bothered by there being voltage on the output side when it isn't being powered. You can/probably should use a multi-meter and see if any current is flowing back in to it with it powered off. Don't want to find your main battery dead because this thing has been trickling it off slowly. Or just go with a diode and have some peace of mind on both counts.
The Following User Says Thank You to Stubby79 For This Useful Post:
puddleglum (12-25-2017)
