Old 12-27-2017, 04:02 PM   #5 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Why does it have a rake? What tire sizes do you have on it now? It should be level from the factory.
Most cars do it to look cool. It supposed to look "more aggressive"
Some designs even have a rake built into the body so the car looks like it has a rake to it when it is level.
195/65/15 Cooper CS3.
I think I've decided on 185/65/15 up front and 175/65/15 in the rear. Only a 2% difference which should work and will let me reduce my rolling coefficient how I want to. Think load support is unchanged, but lateral grip is decreased. For the most part its not a race car so I'll accept it.
Ill go from 6.2" tread width dry rotted non LRR tires front and rear to: 5.6" & 5.2" combo front and rear that Is LRR. So It should give me the double bonus of a better compound and narrower width. Also OEM speedometers are 2% faster than normal so It will put it back to spot on.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
