Road [torture] testing continues.
An electrically heated rear wheel pant?
Road torture is correct! I think I will have to remove the wheel pant if there is any snow forcasted during my travels in those regions. I don't believe there is a real good design compromise that would allow aerodynamics and snow build up/dispersion at the same time without affecting the performance of either requirement.
The only real way I could heat up that portion would be to divert the exhaust to that area. With my limited budget and knowledge, there's no way I could make it electrically heated.
