Old 12-28-2017, 01:33 AM   #34 (permalink)
cRiPpLe_rOoStEr
Originally Posted by 19bonestock88 View Post
Water vapor? I've considered filtering PCV gases through a catch can and then a bubbler to generate a small part of water/methanol vapor(washer fluid) to induce into the intake tube, would this help any?
Sounds interesting, but I'm not so sure if that would be safe. Maybe routing the PCV gases through a water jacket could be less prone to increase the risk of causing moisture contamination for the oil. Just might need to consider some other alternative to filter the vapors and catch most of the oily remains to prevent them from reaching the intake tract.
