Old 12-28-2017, 02:52 AM   #987 (permalink)
cRiPpLe_rOoStEr
Originally Posted by BamZipPow View Post
The only real way I could heat up that portion would be to divert the exhaust to that area.
Considering that most commercial aircraft nowadays rely on hot air bled out of the compressor, maybe it wouldn't be so pointless to use the heat from the exhaust flow to de-ice that area. I know it may sound like comparing apples to oranges, but you could try it. But it would require you to make an adjustable exhaust diffuser to blast hot exhaust gases in that area only when the heat is needed.
With my limited budget and knowledge, there's no way I could make it electrically heated.
There might be some reasonably cost-effective way to heat it electrically. Why not try some heater pad like those ones that some people are using to heat the oil sump?
The Following 2 Users Say Thank You to cRiPpLe_rOoStEr For This Useful Post:
aerohead (12-30-2017), BamZipPow (12-29-2017)
