Old 12-28-2017, 10:07 AM   #48 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Quite true, and that is the plan. I'm just waiting for discount tire to have a deal on them.
In summer, I do plan to do a mod to disable this (put it on a switch) to increase fuel economy. The electric heater kicks in under set conditions, but one of them is until the coolant temp is up to 167F! By then you should have very hot heat coming out of the vents.
Have you looked to see how it's programmed? My car only allows it under certain conditions:
temp below 50/ coolant under xxx/Eco mode/ max heat/ low vent. How they're programmed they seem to really only work when there just isn't any heat coming from the heater.
Also fantastic mileage for -1F. Thats some thick air for that mileage.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
