Originally Posted by Xist
Arizona is having a warm winter because of global warming. The rest of the U.S. is having an especially cold winter because of global warming.
Which is it? Does global warming make winters colder or warmer?
If global warming makes winters worse then cranking up the heat only makes it worse!
As a kid it wasn’t uncommon to have snow at Halloween and snow still melting in June.
Up till 3 weeks ago it was on and off 60’s, now temperatures are below zero which around here is pretty normal this time of year.
In the past a real -40f did happen in a January/ February on and off, I have not seen that in a long time.
Just because it gets cold for a brief period in January / February doesn’t mean much when it follows a abnormally warm period when it normally would be cold
