Old 12-28-2017, 05:11 PM   #41 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Daox, in the diagram above your fan is sucking in cold, outside air, which then wastes all heat which is not absorbed by the coolant by dumping it into the atmosphere.
Looping it back to the intake would help you recycle this waste heat, getting hotter air, so increasing heat transfer to the coolant.
If the air in the closed loop should not be heated once the coolant is hot, a simple trap door could open to vent the loop. This door could either have a (normally open) closing mechanism wired to the fan, or be closed by the pressure the fan generates.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Daox (12-28-2017)
