Easy, spend lots of money.
More on the rest of the car than the engine it's self. You will need a 6 speed to get good fuel economy and get up and go performance.
Add an oil to coolant heat exchanger to get the oil up to temperature.
My Trans Am is already a 6-speed. I could not possibly imagine trying to drive this car with an automatic in the heart of blizzard conditions, you would spin out into a guard rail/cement block or act as a crooked thrown bowling ball headed for "pins" in the opposing lane of traffic. Not good!
The only issue with an oil-to-coolant heat exchanger is that in below freezing weather the engine oil will likely warm up faster than the coolant, which takes a good amount time to get up to temperature while letting the car idle for 15 minutes.
