Old 12-31-2017, 07:51 PM   #16 (permalink)
Phoenix'97
Phoenix'97's Avatar
White Steed - '97 Pontiac Firebird Trans Am WS6
I have found that unless you have an oil to coolant heat exchanger the oil takes a lit longer to warm up.
I will have to research it but it is hard to believe. The motor oil is cycling through the motor long before the coolant starts cycling through after warming up, I don't see how it is possible for the coolant to warm up faster than the motor oil...
