Old 12-31-2017, 11:39 PM   #22 (permalink)
Phoenix'97
Phoenix'97's Avatar
White Steed - '97 Pontiac Firebird Trans Am WS6
Most vehicles I owned will allow me to put my hand on the oil pan if I stop as soon as the coolant is up to operating temperature on a cold day.
There are at least a few posts on here talking about oil to coolant warm up times on exchanger less systems.
On a vehicle that does not have a heat exchanger or cooler the oil can get hotter than the coolant by up to 20°F, but it takes a while.
I'm putting together a 454 bored and stroked out to 489 with 11:1 compression. Instead of running expensive fuel all the time I am going to try to run regular unleaded and then have cheap water methanol kick in when I get on the throttle.
Okay, so you are using the exchanger to cool down the motor oil to help cool down the motor. Hmmm, I need to research it. I am not so sure I even need it, especially for the motor oil that I am using.
