Old 01-04-2018, 04:09 PM   #54 (permalink)
cRiPpLe_rOoStEr
Even if the experience of improving the efficiency of this car doesn't effectively lead to money savings in the long run, it still sounds interesting to say the least, both in the environmental aspect and to provide knowledge about the usage of another alternate fuel that may eventually become a viable for other operators with easier access to it.
Originally Posted by elhigh View Post
RE: lean burn. It won't cook your pistons when done right, you're leaning the engine so far past stoich it starts to cool off the chamber temps again. You'll need sensors enough to know if things are getting too hot inside but Honda did it and shoot, pilots using plain ol' knobs and gauges in piston engine aircraft can do it - no electronic engine controls at all. Just gotta keep your eyes on the head temps.
Sometimes I get the willing to pick an old carburettor-fed car and adapt some manual mixture control like the gasser (or ethanol) aircraft.
