Old 01-05-2018, 05:16 PM   #65 (permalink)
oil pan 4
With out some pretty fancy controls the leanest you can go while driving down the road is going to be about 18:1.
Any leaner than that and you will have to have spark time tied into a wide band air fuel ratio monitor.
It's doable but I think most of the gains are already had if you can drive along at between 16 to 17:1 air fuel ratio.
If I'm going to do an electric car, might as well be a leaf.
A truly fast electric conversation runs into at least the tens of thousands of dollars. Then you still can't take it on a road trip.
