Old 01-07-2018, 01:16 PM   #5 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by RedDevil View Post
The cheapo LEDs typically have a resistor to 'regulate' current; of the 12 Volt in the cluster 3 goes into powering the LED and 9 into heating up the resistor... which almost defeats the purpose of having LEDs.
IDK how the SuperbrightLEDs are regulated. They may be the same. You gotta investigate; if you have one cut it open and take a look... or find someone who did that. Internet is a thing.
The resistor is in series, I don't think it can increase the LED's current draw. But I suspect that resistor is the weak link in the cheapo LEDs. The ones that have died on me had both dead LEDs and dead resistors. I suspect the resistor shorted out and then the LED burnt out on the full 12v.
I have a 194 from SBL in front of me right now. Two resistors and a pair of semiconductors that I can't make out through the case. But I know they're acting as a bridge rectifier, the bulb is not polarity-sensitive.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
