And the power output of the gasoline engine plays no role in this equation? Lets say that this engine has no issue producing lots of low end torque, so even with the taxation from the rear mounted hub generators, it would still be able to produce the same power on the same gallon or spritz of gasoline per cycle per cylinder.
This is why it is nagging me!
