Old 01-09-2018, 06:20 PM   #165 (permalink)
Phoenix'97
Phoenix'97's Avatar
White Steed - '97 Pontiac Firebird Trans Am WS6
I can think of a few ways. The most simple in principle would be to have a second "pedal" behind your gas pedal, so when it gets past a certain point, you start pressing the electric motor's throttle too.
Another method would be to tie motor throttle to manifold vacuum, so that the less vacuum you have, the more assist you get, and you get regen when vaccum is really high. Or, maybe you can tie it to throttle position sensor.
A really good system would probably take all of these factors and more into account (e.g. vehicle speed), and have some formula to derive how much assist you should get.
Boy do I have a plethora of things to look into. I won't dismiss the hybrid technology but yeah, if it won't work the way I was hoping then that part I have to dismiss and admit I was wrong about it.
I won't go too crazy with this car.
