Old 01-10-2018, 01:31 PM   #15 (permalink)
Jdesign
Ecostanced
Jdesign's Avatar
ES9 - '03 Honda CIVIC Hybrid
Originally Posted by S Keith View Post
Lastly, after you disconnect the charger, let the pack sit overnight (10+ hours) and then check the 10 tap voltages to XX.XX accuracy. Take the car for a test drive, allow it to sit form 10+ hours and check them again. Those are the most readily accessible way to see if you have issues inside the pack.
All VERY VERY good information. Thank you again!
The only part I don't understand is the 10 tap voltages. What do you mean by that?
Also the Battery was at 171-173?(I don't remember exactly) when I checked it last night as it was still on the grid charger. I will go at lunch, record the number, remove the grid charger, and let the pack rest for a day, then check the numbers again before driving.
