Originally Posted by Jdesign
The "171" was a guess. I am on my way to check and confirm my final number.
As far as the connector, I can assume that positive voltage is present and I can just use the ohmmeter between the packs negative terminal and each pin to record my findings?
Yes I did have a IMA fault code, I have for a few months, I just havent had time to dig into the battery like I am now.
No. There is a lead to each stick pair, i.e., you just walk the probe from one set of pins to the next. When I can access my dropbox, I'll send you a diagram of the pins.
Codes matter. P1433 or other?
