You shouldn't believe the FUD. There is no data manipulation. The science is strong and as certain as we can be.
Read "Merchants of Doubt" - and follow the money. Fossil fuel companies are desperate to keep earning record profits.
Exxon knew in 1978 that humans are causing climate change.
So you just chose to ignore the fact that the institutions keep falsifying data to support their own cause?
The climate changes, man has had some effect. The idea that man is the driving force behind climate change dies a little more each day.
The best example the ipcc just admitted they were overestimating the effect CO2 had on the climate by double what it actually is. Their words, not mine.
I guess what the ipcc says is FUD too.
With a little luck in a few more years the ipcc will meet the same fate as the Chicago carbon credit exchange.
